944 Turbo '87 Young man's first Porsche
Olli951
Re: 944 Turbo '87 Young man's first Porsche
#16 Post by Olli951 »
We have spent some time to locate parts we need for the project. Also some clean up has been done. Most of the undercarriage parts will be either yellow passived or powder coated back to their original condition.
Some rear axle parts (bolts, nuts, washer etc.) in citric acid bath
Parts after citric acid treatment
Parts will look like this after new yellow passive (ZNC) tratment
Olli
-88 951 3.0L 16V
rob3rt
#17 Post by rob3rt »
nice thread, looking good. :)
Robert Nygårds
924 -83 (Såld)
BMW 318Ti -96 | Günther
Olli951
#18 Post by Olli951 »
Project continues. Some aluminium undergarriage parts are now media blasted, and will be powder coated with clear powder. My son managed to trade his old rusty original 951 stabilistors to the new ones. I suppose guy who agreed to this deal is some kind of mental case :wink:
Olli
-88 951 3.0L 16V
Olli951
#19 Post by Olli951 »
Got some pictures from Niklas who was the last owner of son's 951 in Sweden. Pictures were taken in 2005. We have a long way to go :)
Visit a friend who runs a autoglass shop. He promised to come over to my son's garage and install a new windshield to 951.
His hobby cars are old Detroit iron.
If you don't have nothing to do in your summer cottage the Finnish lake distric (little bit over 200000 lakes over there) just clean and fix some of your 951's wireing loom
Olli
-88 951 3.0L 16V
Olli951
#20 Post by Olli951 »
Most of the parts have been powder coated and some of them are still at the platers shop to be yellow passived. Most undergarriage parts got rather dull "Platinum Grey" powder on them. We wanted to use powder coat, because it would be easier to keep these parts clean compared to "plain" aluminium. Here's picture of one control arm from where you get the idea of the color we used.
As a side project we re-contioned front brakes of friends 951
Olli
-88 951 3.0L 16V
Dirfors
Telefon: 0767860514
Bilmodell: 944 N/A
#21 Post by Dirfors »
I love this thread! Good job.
Porsche 944 N/A -84
http://www.944sverige.com/forum/viewtop ... 17&t=22391" onclick="window.open(this.href);return false;
Trummis i All Used
http://www.myspace.com/allusedmain" onclick="window.open(this.href);return false;
Olli951
#22 Post by Olli951 »
Started to restore steering rack we got from a friend. It's a total mess, but still useable. Put it to the parts, now waiting for some soda blasting for aluminium parts and fresh yellow passived surface for "tube". I found ZF repair kit from my stock of unused parts :)
(here's poor quality phone picturs)
We got a "new" brake booster from the another friend because previous owner sold the original one.
Before:
After:
Olli
-88 951 3.0L 16V
Olli951
#23 Post by Olli951 »
Restored clutch cylinders.Removed surface rust, then re- painted them. Since we are on tight budjet we used Mercedes W124 rubber parts, which are a direct fit also to 951. Total cost less than 10€ :)
Olli
-88 951 3.0L 16V
firefish
Bilmodell: 968CS
#24 Post by firefish »
Nice job!
What kind of wear is to be expected on a steering rack, how do they go bad?
My front end is brand new with all the good parts but I still lack some of the "feel" that I imagine should be there. I suspect that the rack might be the culprit, it is the only thing left untouched, but I'm not looking forward to taking it apart...
Magnus W
www.bike.se
Olli951
#25 Post by Olli951 »
Usually the worst thing what you could have with rack is the damaged surface of teethed saft itself. If there is deep scratches, even the new gaskets won't hold 110 bar pressurised fluid behind them. Otherwise there usually are not much to be worried about.So when you repair steering rack be sure to remove all the road dirt, dust, sand etc. from all the parts before re-assembly.
Olli
-88 951 3.0L 16V
Olli951
#26 Post by Olli951 »
My son bought a set of '88 951 S CS wheels. Also these wheels needs to be restored. Wheels need some mechanical work and after that some kind of new surface.
Got yesterday a great pair of 964 C4 front calipers. Calipers were taken from this C4:
Calipers are (as you can see from picture) as good as new :D
Opinion needed; should we stay black finish or should we use "Corso Traffico" ? See the picture of GT3 set up i just rebuild:
Olli
-88 951 3.0L 16V
Olli951
#27 Post by Olli951 »
Calipers were so sooty & rusty i wouln't like to touch them. Good old trick, citric acid, helped again :)
I put calipers to bath yesterday evening:
Took them for a rinse this morning. After rinse with warm water:
Olli
-88 951 3.0L 16V
Olli951
#28 Post by Olli951 »
Disassembled calipers.Some difficulties with burnt seals, which glued pistons very effectively. Also had to use MIG-welder to couple of screws to be able to take them off. Otherwise "business-as-usual" caliper job. Now they are ready to get a new surface.
Removing a stuck screw:
Disassembled calipers:
Olli
-88 951 3.0L 16V
Dea
Bilmodell: 944 Turbo
#29 Post by Dea »
Nice work!
What citric acid mix do you use?
The ZNC treatment, does it have the same problem with hydrogen-brittling as normal "gulkromatering" ?
/Dea
Porsche 944 Turbo -90
PCS #9245
Olli951
#30 Post by Olli951 »
I usually put 5DL to 10L. I have not noticed any side effects after ZNC treatment, only to pressure cast zinc parts it is not friendly.
Olli
-88 951 3.0L 16V
