821 hk motor och MÄNGDER med prestandadelar
gurra
Sponsor
#1 Post by gurra »
Revline säljer ut ALLA prestandadelar för 944/968.
skicka maila på gustaf @ revline . se vid intresse!
Performance parts
Stroker kit med:
968 91 mm offset stroked crank. Nitride hardened
JE pistons, 104.15 mm bore
Carillo 4G63 stroker rods
968 block with Darton MID - NOTE cracked and not usable. However the sleeves, girdle pins, oil squirters etc can likely be reused
ARP 625+ 9/16 head stud set
ARP 2000 9/16 head stud set
968 ported big valve solid lifter head inc solid lifters carefully setup to be used without lash caps
968 valve cover powder coated green
Custom billet camshafts for solid lifter head
Billet dry sump oil pan, green anodized
Dry sump kit with 4 stage Aviaid pump, brackets, AOS plugs etc etc and NEW ARE cast pan
Billet water pump block off for electric pump, green anodized
Chromoly lightweight billet flywheel & Sachs motorsport 140 mm 3 plate clutch (1400 Nm) with Sachs slave cyl
Short runner big plenum intake manifold, 75mm throttle body, fuel rail
2x Custom 321 headers for relocated rearwards turbo. T4 divided flange. 1 new and 1 used header with Zircotech coating
Custom made engine mounts
Stock parts:
Porsche 968 cylinder head. Stock valves & stiffer valve springs included but not assembled
968 variocam unit
104 mm cylinder block
951 headers (no crossover)
Misc engine mounts
2x bell housings
2x 951 starters
Complete 968 3.1l 16v turbo long block. Did 821 hp at the dyno in 2018. Not used since.
No headers or intake manifold
Darton MID sleeves
Stroked and nitride hardened crank
Dry sump pan
968 Big valved ported head, hydraulic lifters
High lift / long duration camshafts
Powder coated cam cover (gold)
Balance shaft delete
Athena Cooper ring head gasket
PCS #6556
peed
Bilmodell: 968 CS/Turbo
Årsmodell: 1992
Re: 821 hk motor och MÄNGDER med prestandadelar
#2 Post by peed »
Gustaf lägger ni ner 968 satsningen eller blir det billet motor?
/Peder
968 Turbo S/RS tribute -92
928 -79
924 S -86
gurra
Sponsor
#3 Post by gurra »
Det blir en billetmotor av en annan motortyp.
PCS #6556
Torbjorn968
#4 Post by Torbjorn968 »
Thor?
gurra
Sponsor
#5 Post by gurra »
Om jag hade fått en krona för varje gång jag svarat på frågan :lol:
som jag skrev ovan, "annan motortyp", dvs inte porschebaserat.
PCS #6556
gurra
Sponsor
#6 Post by gurra »
Har öppnat en webshop med alla delar. Mer delar, bilder osv uppdateras kontinuerligt!
https://www.revlinestore.se/
PCS #6556
