951 | Turbo SS "The Beast"
Re: 951 | Turbo SS "Televerket racing"
#346 Post by Maxx »
Olli951 wrote:One possibility is to use only one ligh-unit, like is the case on this finnish 968 Turbo. Jarmo used one Hella unit, which has both low & high beams. This gives you a possibility to place light unit to the center point of the bucket, which most likely eliminates blind spots which bucket edges can cause.
Olli, do you know where he got those lights from? (Lights, buckets and everything.)
Olli951
#347 Post by Olli951 »
Light units are from Hella's product line. Bucket, glass etc. are made by Jarmo. He made bucket from aluminium & glassfibre.Bottom plate with small grooves is made of plastic wall's meant for shower cabin. Originally it has been transparent, but Jarmo painted it black. Those grooves were so close to the ones which can be found from new Porsche lights, lie 997, Boxster etc. Jarmo is making evo version of glass. he's going to make a bit curved ones to fit better to fenders form.
Olli
-88 951 3.0L 16V
bergodalvana
Telefon: 0761361306
#348 Post by bergodalvana »
Den Kolfiber-foilerade huven och frontplåten har kommit på i helgen, så det blev en liten tur runt kvarteret idag, -5 och feta sommardäck är ingen bra kombination.
944 -84 "tysken" (krockad)
944Sverige medlem: 1780
PCS:11959
bergodalvana
Telefon: 0761361306
#349 Post by bergodalvana »
Jag fick en vinge av Andreas här på forumet i somras, den har tidigare suttit på Jägermeistern här på forumet. Efter lite lagande, tillpassande på bilen och lite kolfiberfoile så blir det rikitgt bra får jag säga.
PCS:11959
hanilton199
Bilmodell: Porsche 944 -84 NA
#350 Post by hanilton199 »
riktigt snyggt
Är ägare av porsche 944 -84
hanilton199
#351 Post by hanilton199 »
riktigt snyggt
hanilton199
#352 Post by hanilton199 »
riktigt snyggt
hanilton199
#353 Post by hanilton199 »
riktigt snyggt
MattiasA
Bilmodell: 944Turbo -90
#354 Post by MattiasA »
bergodalvana wrote:Jag fick en vinge av Andreas här på forumet i somras, den har tidigare suttit på Jägermeistern här på forumet. Efter lite lagande, tillpassande på bilen och lite kolfiberfoile så blir det rikitgt bra får jag säga.
Har du gett upp den STORA vingen ? :(
/Mattias
Mattias Andersson
944 turbo-90
PCS 10746
bergodalvana
Telefon: 0761361306
#355 Post by bergodalvana »
Njae... alltid bra att ha alternativ.
problemet med den stora vingen är besiktningen och att jag måste flytta på nummerplåten varje gång.
Jag fick denna vingen och leker väl med tanken, tröttnar man kan man ju alltid byta :)
PCS:11959
bergodalvana
Telefon: 0761361306
#356 Post by bergodalvana »
Ihelgen har det vart en liten premiärtur med den nya turbon och lite ändringar i sprutet.
'''turbon svarar mycket tidigare och trevligare än den tidigare jag hade.
Redan vid 3200 varv kommer laddet och idag var jag uppe i 1,7 bar så det rörde på sig lite.
PCS:11959
hanilton199
#357 Post by hanilton199 »
Va gör den 0-100 på ett ungefär?
MattiasA
#358 Post by MattiasA »
bergodalvana wrote: I helgen har det vart en liten premiärtur...
:shock: Jösses. Får inte bilen den välbehövliga vinterdvalan...? :mrgreen:
Det skall bli kul att få se den IRL - jag har ju inte sett den sen den stod grålackad i garaget i U-A. Du kanske hänger på påsktouringen med PCS? Den passerar väl nästan dina hemmatrakter...
Kör försiktigt :roll: så ses vi i vår.
/Mattias
Mattias Andersson
944 turbo-90
PCS 10746
bergodalvana
Telefon: 0761361306
#359 Post by bergodalvana »
hanilton199 wrote:Va gör den 0-100 på ett ungefär?
Runt 20 minuter... :)
Nä, skämt åsido så har jag inte testat ännu, jag är tvungen att byta laddtrycksmätare då den gamla bara gick till 1,5bar.
Ska prova när det börjar bli lite säkrare att gasa på utan att oroa sig för isfläckar. :)
PCS:11959
bergodalvana
Telefon: 0761361306
#360 Post by bergodalvana »
/Mattias
Hehe... jag vill väl mest ha lite framförhållning så allting funkar när säsongen väl drar igång.
Ja, det var ju ett tag sen du hälsade på, du är varmt välkommen på fika när det blir lite varmare.
Jag har slarvat med inbetalningen till PCS men det ska jag ta itu med nu, så det hoppas jag att jag kan vara med på. :)
PCS:11959
