group buy charlie cnc billet a-arms 944
anders44
#1 Post by anders44 »
Hei, er en group buy på rennlist nu, vi trenger 10stk som skal kjøpe 1987+ (lange) bærearmer, de er i billet alu, mao veldig sterke og lette. det er 19mm pins på de, og de er lange, mao de løser problemet med feil vinkler på A armene på senket bil, og med 19mm pinne så får de nok styrke.
pris blir ca 2000USD
sitat selger
Priced per pair of arms. (2)
We consider these to be the strongest and best quality control arms available. Built from a solid billet of 7075T7 aluminum. CNC machined and hard anodized to a satin finish.
They feature a replaceable spherical bearing ball joint with a larger 19mm ball joint pin made of a special alloy offering exceptional strength and durability. The original spindle ball joint pin bore must be enlarged from 17 to 19mm. We offer this service if necessary.
Additionally, a replaceable spherical bearing for the sub-frame mount with machined spacers is utilized to complete the assembly.
Billet aluminum caster blocks with spherical bearings are also available.
